MQTT Things and Channels Binding
MQTT Architecture
  • When a device (a client) wants to send data to the broker, we call this operation a “publish”.
  • When a device (a client) wants to receive data from the broker, we call this operation a “subscribe”.
Publish and Subscribe
MQTT Topics
Because every manufacturer can device on his own on which topic his devices publish, this binding can unfortunately not provide any auto-discovery means.
Supported Things
Supported Channels
  • string: This channel can show the received text on the given topic and can send text to a given topic.
  • number: This channel can show the received number on the given topic and can send a number to a given topic. It can have a min, max and step values.
  • dimmer: This channel handles numeric values as percentages. It can have min, max and step values.
  • contact: This channel represents a open/close state of a given topic.
  • switch: This channel represents a on/off state of a given topic and can send an on/off value to a given topic.
  • colorRGB: This channel handles color values in RGB format.
  • colorHSB: This channel handles color values in HSB format.
  • image: This channel handles binary images in common java supported formats (bmp,jpg,png).
  • datetime: This channel handles date/time values.
  • rollershutter: This channel is for rollershutters.
Channel Configuration
  • stateTopic: The MQTT topic that represents the state of the thing. This can be empty, the thing channel will be a state-less trigger then. You can use a wildcard topic like "sensors/+/event" to retrieve state from multiple MQTT topics.
  • transformationPattern: An optional transformation pattern like JSONPath that is applied to all incoming MQTT values.
  • transformationPatternOut: An optional transformation pattern like JSONPath that is applied before publishing a value to MQTT.
  • commandTopic: The MQTT topic that commands are send to. This can be empty, the thing channel will be read-only then. Transformations are not applied for sending data.
  • formatBeforePublish: Format a value before it is published to the MQTT broker. The default is to just pass the channel/item state. If you want to apply a prefix, say "MYCOLOR,", you would use "MYCOLOR,%s". If you want to adjust the precision of a number to for example 4 digits, you would use "%.4f".
  • postCommand: If true, the received MQTT value will not only update the state of linked items, but command it. The default is false. You usually need this to be true if your item is also linked to another channel, say a KNX actor, and you want a received MQTT payload to command that KNX actor.
  • retained: The value will be published to the command topic as retained message. A retained value stays on the broker and can even be seen by MQTT clients that are subscribing at a later point in time.
  • trigger: If true, the state topic will not update a state, but trigger a channel instead.
Channel Type "string"
  • allowedStates: An optional comma separated list of allowed states. Example: "ONE,TWO,THREE"
Channel Type "number"
  • min: An optional minimum value.
  • max: An optional maximum value.
  • step: For decrease, increase commands the step needs to be known
Channel Type "dimmer"
  • on: A optional string (like "ON"/"Open") that is recognized as minimum.
  • off: A optional string (like "OFF"/"Close") that is recognized as maximum.
  • min: A required minimum value.
  • max: A required maximum value.
Channel Type "contact", "switch"
  • on: A optional number (like 1, 10) or a string (like "ON"/"Open") that is recognized as on/open state.
  • off: A optional number (like 0, -10) or a string (like "OFF"/"Close") that is recognized as off/closed state.
The contact channel by default recognizes "OPEN" and "CLOSED". You can connect this channel to a Contact item. The switch channel by default recognizes "ON" and "OFF". You can connect this channel to a Switch item.
Channel Type "colorRGB", "colorHSB"
  • on: An optional string (like "BRIGHT") that is recognized as on state. (ON will always be recognized.)
  • off: An optional string (like "DARK") that is recognized as off state. (OFF will always be recognized.)
  • onBrightness: If you connect this channel to a Switch item and turn it on,
Channel Type "location"
Channel Type "image"
Channel Type "datetime"
Channel Type "rollershutter"
  • on: An optional string (like "Open") that is recognized as UP state.
  • off: An optional string (like "Close") that is recognized as DOWN state.
  • stop: An optional string (like "Stop") that is recognized as STOP state.
Rule Actions
This binding includes a rule action, which allows to publish MQTT messages from within rules. There is a separate instance for each MQTT broker (i.e. bridge), which can be retrieved through
val mqttActions = getActions("mqtt","mqtt:systemBroker:embedded-mqtt-broker")
where the first parameter always has to be mqtt and the second (mqtt:systemBroker:embedded-mqtt-broker) is the Thing UID of the broker that should be used. Once this action instance is retrieved, you can invoke the publishMQTT(String topic, String value) method on it:
mqttActions.publishMQTT("mytopic","myvalue")
Limitations
  • The HomeAssistant Fan Components only support ON/OFF.
  • The HomeAssistant Cover Components only support OPEN/CLOSE/STOP.
  • The HomeAssistant Light Component does not support XY color changes.
  • The HomeAssistant Climate Components is not yet supported.
Incoming Value Transformation
Received value Tr. Service Transformation
{device: {status: { temperature: 23.2 }}} JSONPATH JSONPATH:$.device.status.temperature
<device><status><temperature>23.2</temperature></status></device> XPath XPath:/device/status/temperature/text()
THEVALUE:23.2°C REGEX REGEX::(.*?)°
Transformations can be chained by separating them with the mathematical intersection character "∩".
Outgoing Value Transformation
All mentioned channels allow an optional transformation for outgoing values. Please prefer formatting as described in the next section whenever possible.
Format before Publish
This feature is quite powerful in transforming an item state before it is published to the MQTT broker. It has the syntax: %[flags][width]conversion. Find the full documentation on the Java web page.
Here are a few examples:
  • All uppercase: "%S". Just use the upper case letter for the conversion argument.
  • Apply a prefix: "myprefix%s"
  • Apply a suffix: "%s suffix"
  • Number precision: ".4f" for a 4 digit precision. Use the "+" flag to always add a sign: "+.4f".
  • Decimal to Hexadecimal/Octal/Scientific: For example "60" with "%x", "%o", "%e" becomes "74", "3C", "60".
  • Date/Time: To reference the item state multiple times, use "%1$". Use the "tX" conversion where "X" can be any of [h,H,m,M,I,k,l,S,p,B,b,A,a,y,Y,d,e].
    • For an output of May 23, 1995 use "%1$tb %1$te,%1$tY".
    • For an output of 23.05.1995 use "%1$td.%1$tm.%1$tY".
    • For an output of 23:15 use "%1$tH:%1$tM".
Troubleshooting
  • If you get the error "No MQTT client": Please update your installation.
  • If you use the Mosquitto broker: Please be aware that there is a relatively low setting for retained messages. At some point messages will just not being delivered anymore: Change the setting
