Nanoleaf Binding
This binding integrates the Nanoleaf Light Panels.
It enables you to authenticate, control, and obtain information of a Light Panels device. The binding uses the Nanoleaf OpenAPI, which requires firmware version 1.5.0 or higher.
Supported Things
The controller thing is the bridge for the individual panels connected to it. With the controller thing you can control channels which affect all panels, e.g. selecting effects or setting the brightness.
The lightpanel things control the individual panels. You can set the color for each panel or turn it on (white) or off (black).
Discovery
A controller (bridge) device is discovered automatically through mDNS in the local network. Alternatively, you can also provide a things file (see below for more details). After the device is discovered and added as a thing, it needs a valid authentication token that must be obtained by pairing it with your openHAB instance. Without the token the light panels remain in status OFFLINE.
  1. Make sure that the authentication token field in your Nanoleaf controller thing configuration is left empty.
  2. Hold down the on-off button of the controller for 5-7 seconds until the LED starts flashing in a pattern, which turns the device in pairing mode, and openHAB will try to request an authentication token for it.
For a successfully paired and online controller, the individual panels connected to it can be discovered by starting another scan for the Nanoleaf binding (e.g. from the Inbox in Paper UI). All connected panels will be added as separate things to the inbox.
Thing Configuration
Config Description
address IP address or hostname of the light panels controller (e.g. 192.168.1.100)
port Port number of the light panels contoller. Default is 16021
authToken The authentication token received from the controller after successful pairing.
refreshInterval Interval in seconds to refresh the state of the light panels settings. Default is 60.
Config Description
id ID assigned by the controller to the individual panel (e.g. 158)
The IDs of the individual panels can be determined by starting another scan once the controller is configured and online. This will add all connected panels with their IDs to the inbox.
Channels
Channel Item Type Description Read Only
power Switch Power state of the light panels No
color Color Color of all light panels No
colorTemperature Dimmer Color temperature (in percent) of all light panels No
colorTemperatureAbs Number Color temperature (in Kelvin, 1200 to 6500) of all light panels No
colorMode String Color mode of the light panels Yes
effect String Selected effect of the light panels No
rhythmState Switch Connection state of the rhythm module Yes
rhythmActive Switch Activity state of the rhythm module Yes
rhythmMode Number Sound source for the rhythm module. 0=Microphone, 1=Aux cable No
panelColor Color Color of the individual light panel No
The color and panelColor channels support full color control with hue, saturation and brightness values. For example, brightness of all panels can be controlled by defining a dimmer item for the color channel of the controller thing. The same applies to the panelColor channel of a lightpanel thing. More details can be found in the full example below.
Full Example
nanoleaf.things
Bridge nanoleaf:controller:MyLightPanels [ address="192.168.1.100", port=16021, authToken="AbcDefGhiJk879LmNopqRstUv1234WxyZ", refreshInterval=60 ] {
nanoleaf.items
Switch NanoleafPower "Nanoleaf" { channel="nanoleaf:controller:MyLightPanels:power" }
String NanoleafHue "Hue [%s]"
Number NanoleafColorTempAbs "Color temperature [%.000f]" { channel="nanoleaf:controller:MyLightPanels:colorTemperatureAbs" }
String NanoleafColorMode "Color mode [MAP(nanoleaf.map):%s]" { channel="nanoleaf:controller:MyLightPanels:colorMode" }
Number NanoleafRhythmSource  "Rhythm source [%s]" { channel="nanoleaf:controller:MyLightPanels:rhythmMode" }
Color Panel1Color "Panel 1" { channel="nanoleaf:lightpanel:MyLightPanels:135:panelColor" }
Dimmer Panel1Brightness "Panel 1" { channel="nanoleaf:lightpanel:MyLightPanels:135:panelColor" }
Color Panel2Color "Panel 2" { channel="nanoleaf:lightpanel:MyLightPanels:158:panelColor" }
nanoleaf.sitemap
    Frame label="Controller" {
            Switch item=NanoleafPower
            Text item=NanoleafHue
            Text item=NanoleafSaturation
            Slider item=NanoleafColorTemp
            Text item=NanoleafColorMode
            Selection item=NanoleafEffect mappings=["Color Burst"="Color Burst", "Fireworks" = "Fireworks", "Flames" = "Flames", "Forest" = "Forest", "Inner Peace" = "Inner Peace", "Meteor Shower" = "Meteor Shower", "Nemo" = "Nemo", "Northern Lights" = "Northern Lights", "Paint Splatter" = "Paint Splatter", "Pulse Pop Beats" = "Pulse Pop Beats", "Rhythmic Northern Lights" = "Rhythmic Northern Lights", "Ripple" = "Ripple", "Romantic" = "Romantic", "Snowfall" = "Snowfall", "Sound Bar" = "Sound Bar", "Streaking Notes" = "Streaking Notes", "moonlight" = "Moonlight", "*Static*" = "Color (single panels)", "*Dynamic*" = "Color (all panels)" ]
            Text item=NanoleafRhythmState
    Frame label="Panels" {
        Colorpicker item=Panel1Color
        Slider item=Panel1Brightness
        Colorpicker item=Panel2Color
    Frame label="Scenes" {
Note: The mappings to effects in the selection item are specific for each Nanoleaf installation and should be adapted accordingly. Only the effects "*Static*" and "*Dynamic*" are predefined by the controller and should always be present in the mappings.
nanolead.rules
rule "UpdateHueAndSat"
rule "ShowRainbowScene"
    val long pause = 200
    var hue = 0
    var direction = 1
        Thread::sleep(pause)
        hue = hue + (5 * direction)
        if(hue >= 359) {
            hue = 359
            direction = direction * -1
        else if (hue < 0) {
            hue = 0
nanoleaf.map
ON = Yes
OFF = No
effects = Effect
hs = Hue/Saturation
ct = Color Temperature
