Nikobus Binding
This binding allows openHAB to interact with the Nikobus home automation system.
Demo Video Nikobus
More specifically, it allows openHAB to:
  • send (simulated) button presses to the Nikobus,
  • react to button presses which occur on the Nikobus,
  • change the status of switch channels on a Nikobus switch module,
  • request the status of switch channels on a Nikobus switch module,
  • change the status of dimmer channels on a Nikobus dimmer module,
  • request the status of dimmer channels on a Nikobus dimmer module,
  • send commands to the Nikobus roller shutter module.
This binding works with at least the following hardware:
  • PC-link module (05-200),
  • Push buttons (05-060-01, 05-064-01), RF Transmitter (05-314), PIR Sensor (430-00500),
  • 4 channel switch module (05-002-02),
  • 12 channel switch module (05-000-02),
  • 12 channel dimmer module.
Supported Things
The binding supports a serial connection via nikobus:pc-link bridge to the Nikobus installation (PC-Link module):
The bridge enables communication with other Nikobus components:
  • switch-module - Nikobus switch module, i.e. 05-000-02,
  • dimmer-module - Nikobus dim-controller module, i.e. 05-007-02,
  • rollershutter-module - Nikobus roller shutter module,
  • push-button - Nikobus physical push button.
Discovery
The binding does not support any automatic discovery of Things.
Bridge Configuration
The binding can connect to the PC-Link via serial interface.
Bridge nikobus:pc-link:mypclink [ port="<serial port>", refreshInterval=<interval> ] {
where:
  • port is the name of the serial port used to connect to the Nikobus installation
  • refreshInterval defines how often the binding reads Nikobus module's status, so having i.e. 30 as above, the binding will read one module’s status each 30s, iterating through all modules, one by one. If one does not specify refreshInterval, a default value of 60s is used.
Thing Configuration
Once connected to the Nikobus installation using a bridge, one can communicate with:
  • switch-module,
  • dimmer-module,
  • rollershutter-module,
  • push-button.
Modules
Each module is defined by its address and contains 12 outputs (channels), where output-1 corresponds to module's first output, output-2 to module's second output and so on. If physical module has less outputs, only those channels can be used (i.e. 05-002-02 has only 4 outputs, so only channels 1-4 can be used).
Large module contains 2 channel groups, where the first group controls channels 1-6 and the second one controls channels 7-12. The small module contains only a single channel group controlling all 4 channels.
All commands sent to/received from the Nikobus switch module are for a single channel group.
In order to be able to read the status of a Nikobus module channel or to switch a channel directly on the module without mimicking a button press, items for each channel of a module needs to be configured.
switch-module
Thing switch-module BC00
Defines a switch-module with address BC00.
channel type description
output-1 Switch Output 1
output-2 Switch Output 2
output-3 Switch Output 3
output-4 Switch Output 4
output-5 Switch Output 5
output-6 Switch Output 6
output-7 Switch Output 7
output-8 Switch Output 8
output-9 Switch Output 9
output-10 Switch Output 10
output-11 Switch Output 11
output-12 Switch Output 12
dimmer-module
Thing dimmer-module D969
Defines a dimmer-module with address D969.
output-1 Dimmer Output 1
output-2 Dimmer Output 2
output-3 Dimmer Output 3
output-4 Dimmer Output 4
output-5 Dimmer Output 5
output-6 Dimmer Output 6
output-7 Dimmer Output 7
output-8 Dimmer Output 8
output-9 Dimmer Output 9
output-10 Dimmer Output 10
output-11 Dimmer Output 11
output-12 Dimmer Output 12
Thing rollershutter-module 4C6C
Defines a rollershutter-module with address 4C6C.
output-1 Rollershutter Output 1
output-2 Rollershutter Output 2
output-3 Rollershutter Output 3
output-4 Rollershutter Output 4
output-5 Rollershutter Output 5
output-6 Rollershutter Output 6
Buttons
Once an openHAB item has been configured as a Nikobus button, it will receive a status update to ON when the physical button is pressed. When an item receives the ON command from openHAB, it will send a simulated button press to the Nikobus. This means one could also define virtual buttons in openHAB with non-existing addresses (e.g., 000001) and use those in the programming of Nikobus installation.
To configure an item for a button in openHAB with address 28092A, use the following format:
Thing push-button 28092A
Since all the channels in the entire channel group are switched to their new state, it is important that openHAB knows the current state of all the channels in that group. Otherwise a channel which was switched on by a button, may be switched off again by the command.
In order to keep an up to date state of the channels in openHAB, button configurations can be extended to include detail on which channel groups the button press affects.
When configured, the status of the channel groups to which the button is linked, will be queried every time the button is pressed. Every status query takes between ~300 ms, so to get the best performance, only add the affected channel groups in the configuration, which has the following format:
Thing push-button <address> [ impactedModules = "<moduleAddress>-<channelGroup>, <moduleAddress>-<channelGroup>, ..." ]
where:
  • moduleAddress represents the address of the switch module,
  • channelGroup represents the first or second channel group in the module.
Example configurations may look like:
Thing push-button 28092A [ impactedModules = "4C6C-2" ]
In addition to the status requests triggered by button presses, there is also a scheduled status update interval defined by the refreshInterval parameter and explained above.
Full Example
t.b.d.
