Overview
A variety of different parts of openHAB can be extended, we go through all of them.
openHAB uses git as its version control system and GitHub for hosting the different repositories and source code. You will get in contact with git in many places and it makes sense to get familiar with its basic commands and concepts. There are many pages to learn about Git. Try git - the simple guide as a start.
Add-ons and the core itself are written in Java. Java is not hard to learn, but it helps if you have a general technical understanding of programming languages.
The different guides of this chapter assume that you are somewhat familiar with Java 8 and that you have a rough idea of Git's workflow (eg "checkout", "branches", "push").
Choose the Right Concept
openHAB allows you to build up on the following concepts:
  • Bindings: A binding connects to external services or devices,
  • Automation engine module: A trigger, condition or action that can be used in automation rules (or scripts),
  • Transformation / Profiles: Can be used to transform a Thing Channel value before it is assigned to an Item,
  • an IO service: Exposes openHAB internals via a defined interface (for example the REST interface, HomeKit or Hue Emulation Service)
  • a Persistence service: Persist item state updates and/or changes and allow them to be retrieved for specific points in time.
  • Natural language processing skill: Executes something depending on the understood Intents and returns something back to the user,
  • Audio sinks/sources: Extend where audio can be played on or implement audio sources.
  • and many more (not covered yet).
Sometimes though its just not worth writing a binding and you are better off just using an http action in a rule or script to retrieve some values.
Therefore: First think what you want to achieve! Check our community forum and discuss your concept.
Setup the Development Environment
Development can happen on any of the supported operating systems (Windows, Mac OS, Linux).
  1. Git For retrieving our source code and push changes back. On Windows: Must be available in %PATH%
  2. Maven 3.x Our buildsystem tool. On Windows: Must be available in %PATH%
  3. Java JDK 8, for example from Oracle Oracle JDK 8. On Windows: %JAVA% must be set.
Visual Studio Code
Eclipse IDE
Intellij IDE
Not sure what to choose?: openHAB maintainers use Eclipse IDE.
Develop a NEW binding
To start developing a new binding a script is available to generate the basis for your new binding. This script is specific for binding addons. Folllow these steps to generate your binding:
  1. From the command line in openhab2-addons/bundles directory to create a skeleton of a new binding mynewbinding run:
    On Linux:
    ./create_openhab_binding_skeleton.sh  MyNewBinding "<Author>" <GitHubUsername>
    On Windows:
    create_openhab_binding_skeleton.cmd MyNewBinding "<Author>" <GitHubUsername>
    Use your full name for <Author>.
  2. Accept with Y when the skeleton configuration asks for it.
  3. From the /openhab2-addons/bom/openhab-addons directory run:
    mvn -DskipChecks -DskipTests clean install
    to rebuild the list of bindings in the BOM (Bill Of Material) and make your new binding visible from the IDE launch configuration
  4. From openhab2-addons root you can build your binding with maven:
    mvn clean install -pl :org.openhab.binding.mynewbinding
    Where mynewbinding is the name of your new binding. Some additional maven options that may help:
    • -U: Forces all dependencies to be downloaded again.
    • -am: Builds all projects in openhab2-addons your project dependends on.
    • -o: Won't update any dependencies.
    • -DskipChecks: Skips the static analysis checks
    • -DskipTests: Skips the unit tests
  5. To start your new binding it's a good practise to commit your code on a new git branch:
    git checkout -b <mynewbranch>
  6. Open Eclipse or your favorite editor and import your new binding project
