openHABian - Hassle-free openHAB Setup
The Raspberry Pi and other small single-board computers are quite famous platforms for openHAB. However, setting up a fully working Linux system with all recommended packages and openHAB recommendations is a boring task taking quite some time and Linux newcomers shouldn't worry about these technical details.
A home automation enthusiast doesn't have to be a Linux enthusiast!
openHABian aims to provide a self-configuring Linux system setup specific to the needs of every openHAB user. To that end, the project provides two things:
  • Complete SD-card images pre-configured with openHAB and many other openHAB- and Hardware-specific preparations for the Raspberry Pi and the Pine A64
  • The openHABian Configuration Tool to set up and configure openHAB and many related things on any Debian/Ubuntu based system
Table of Content
Features
The following features are provided by the openHABian images out of the box:
Additionally the openHABian Configuration Tool openhabian-config is included and provides the following optional settings and components:
openHABian-config menu
Quick Start
Here you'll find supported and tested installation platforms and instructions.
Raspberry Pi
Flash, plug, wait, enjoy: The provided image is based on the Raspbian Lite standard system. On first boot the system will set up openHAB and the mentioned settings and tools. All packages will be downloaded in their newest version and configured to work without further modifications. The whole process will take a few minutes, then openHAB and all other needed tools to get started will be ready to use without further configuration steps. openHABian is designed as a headless system, you will not need a display or a keyboard.
Learn more about the Raspberry Pi as your platform for openHAB and about the requirements over in our Raspberry Pi article.
Setup:
You can stop reading now. openHABian has installed and configured your openHAB system and you can start to use it right away. If you want to get in touch with the system or want to install one of the previously mentioned optional features, you can come back here later.
Ready for more? Connect to your Raspberry Pi SSH console using the username openhabian and password openhabian. You will see the following welcome screen:
openHABian login screen
➜ Continue at the "openHABian Configuration Tool" chapter below!
Pine A64
We provide a ready to use system image for the Pine A64. The image is based on the official Ubuntu Base Image by longsleep. On first boot the system will set up openHAB and the mentioned settings and tools. All packages are downloaded in their newest version and configured to work without further modifications. The whole process will take a few minutes, then openHAB and all other needed tools to get started will be ready to use without further configuration steps. openHABian is designed as a headless system, you will not need a display or a keyboard.
Learn more about the Pine A64 as your platform for openHAB and about the requirements in our Pine A64 article.
Attention: Unstable behavior has been reported when using the Pine64 with and without a display connected to HDMI. Read about the details in this discussion. As a workaround, please be sure to not have am HDMI display connected during the installation of openHABian.
Setup:
Ready for more? Connect to your Pine A64 SSH console using the username openhabian and password openhabian. You will see the following welcome screen:
➜ Continue at the "openHABian Configuration Tool" section below!
Manual Setup
openHABian also supports general Debian/Ubuntu based systems on different platforms. Starting with a fresh installation of your operating system, install git, then clone the openHABian project and finally execute the openHABian configuration tool:
# install git
sudo apt-get update
sudo apt-get install git
# download and link
sudo git clone https://github.com/openhab/openhabian.git /opt/openhabian
sudo ln -s /opt/openhabian/openhabian-setup.sh /usr/local/bin/openhabian-config
# execute
sudo openhabian-config
You'll see the openHABian configuration menu and can now select all desired actions. The "Manual/Fresh Setup" submenu entry is the right place for you. Execute all entries one after the other to get the full openHABian experience:
openHABian-config menu fresh setup
Attention: openHABian usage on a custom system is supported and should be safe. Still some routines might not work for you. Please be cautious and have a close look at the console output for errors. Report problems you encounter to the openHABian Issue Tracker.
Wi-Fi based Setup Notes
If you own a RPi3, a RPi0W, a Pine A64, or a compatible Wi-Fi dongle you can set up and use openHABian purely via Wi-Fi. For the setup on Wi-Fi, you'll need to make your SSID and password known to the system before the first boot. Additionally to the setup instructions given above, the following steps are needed:
  • Flash the system image to your micro SD card as described, do not remove the SD card yet
  • Access the first SD card partition from the file explorer of your choice (e.g. Windows file explorer)
  • Open the file openhabian.conf in a text editor
  • Uncomment and fill in wifi_ssid="My Wi-Fi SSID" and wifi_psk="password123"
  • Save, Unmount, Insert, Boot
  • Continue with the instructions for the Raspberry Pi or Pine A64
The following instructions are oriented at the Raspberry Pi openHABian setup but are transferable to all openHABian environments.
Once connected to the command line console of your system, please execute the openHABian configuration tool by typing the following command. (Hint: sudo executes a command with elevated rights and will hence ask for your password: openhabian).
The configuration tool is the heart of openHABian. It is not only a menu with a set of options, it's also used in a special unattended mode inside the ready to use images.
⌨ - A quick note on menu navigation. Use the cursor keys to navigate, <Enter> to execute, <Space> to select and <Tab> to jump to the actions on the bottom of the screen. Press <Esc> twice to exit the configuration tool.
Linux Hints
The good news: openHABian helps you to stay away from Linux - The bad news: Not for long...
Regardless of if you want to copy some files or are on the search for a solution to a problem, sooner or later you'll have to know some Linux. Take a few minutes to study the above Tutorials and get to know the most basic commands and tools to be able to navigate on your Linux system, edit configurations, check the system state or look at log files. It's not complicated and something that doesn't hurt on ones résumé.
First Steps with openHAB
After your first setup of openHABian is successful and you are able to access the openHAB dashboard, you should dig into the possibilites. Install Bindings, discover your devices, and configure your smart home. You might want to start defining Items, Sitemap and HABPanel dashboard for your home. To kickstart that process you may check out the openHAB Home Builder.
These are just some first hints. Be sure to read up on the Configuration section of the documentation page to learn more.
Further Configuration Steps
openHABian is supposed to provide a ready-to-use openHAB base system. There are however a few things we can not decide for you.
  • Time Zone: The time zone of your openHABian system will be determined based on your internet connection. In some cases you might have to adjust that setting.
  • Language: The locale setting of the openHABian base system is set to "en_US.UTF-8". While this setting will not do any harm, you might prefer e.g. console errors in German or Spanish. Change the locale settings accordingly. Be aware, that error solving might be easier when using the English error messages as search phrases.
  • Passwords: Relying on default passwords is a security concern you should care about! The openHABian system is preconfigured with a few passwords you should change to ensure the security of your system. This is especially important if your system is accessible from outside your private subnet.
All of these settings can easily be changed via the openHABian Configuration Tool.
Here are the passwords in question with their respective default "username:password" values. All password can be changed from openHABian menu.
  • User password needed for SSH or sudo (e.g. "openhabian:openhabian")
  • Samba share password (e.g. "openhabian:openhabian")
  • openHAB remote console (e.g. "openhab:habopen")
  • Amanda backup password (no default, applied when installing)
  • Nginx reverse proxy login (no default, applied when installing) For manual configuration see here.
  • InfluxDB (No password set by default)
  • Grafana visualization ("admin:admin")
Optional Components
openHABian comes with a number of additional routines to quickly install and set up home automation related software. You'll find all of these in the openHABian Configuration Tool
FAQ and Troubleshooting
For openHABian related questions and further details, please have a look at the main discussion thread in the Community Forum:
If you want to get involved, you found a bug, or just want to see what's planned for the future, come visit our Issue Tracker:
Where can I find a changelog for openHABian?
The official changelog announcements are posted here and here, be sure to check these out regularly. If you want to stay in touch with all the latest code changes under the hood, see the commit history for openHABian. You'll also see added commits when executing the "Update" function within the openHABian Configuration Tool.
Did my Installation succeed? What to do in case of a problem?
A note on patience: Remember to stay calm. The openHABian setup will take 15 up to 45 minutes to complete all steps. This time highly depends on your device's performance, your internet connection and sometimes even on the load of external servers.
RPi note: The progress indication via the green Raspberry Pi LED is currently not possible and hence not part of the openHABian v1.3 image. We will re-add the functionality as soon as the underlying issue is resolved.
openHAB Dashboard
After the installation of openHABian was successful, you should be able to access the openHAB dashboard:
SSH Progress Report
It is always possible to connect to the SSH console of your device (after a few minutes of boot up time). During the setup process you'll be redirected to the live progress report of the setup. The report can also be checked for errors after the installation finished by executing: cat /boot/first-boot.log
The progress of a successful installation will look similar to the following:
openHABian installation log
Wait till the log tells you that the setup was "successful", then reconnect to the device.
SSH Login Screen
If the installation was successful you will see the normal login screen as shown in the first screenshot. If the installation was not successful you will see a warning and further instructions as shown in the second screenshot.
openHABian installation successful
openHABian installation failed warning and instructions
What Next?
If you are not able to access your system via the openHAB dashboard or SSH after more than one hour, chances are high that your hardware setup is the problem. Try using a steady power source and a reliable SD card, double check the network connection. Restart the complete setup process to rule out most other possible causes.
Contact the openHABian community forum thread if the problem persists.
Can I switch from openHAB 2 stable to the testing or unstable branch?
openHABian installs the latest stable build of openHAB 2. If you want to switch over to the snapshot release branch, please do so via the openHABian Configuration Tool. Switching from stable to newer development releases might introduce changes and incompatibilities, so please be sure to make a full openHAB backup first!
Check the Linux installation article for all needed details: Linux: Changing Versions
Where is the graphical user interface?
You've just installed openHABian and are confused. No fancy login screen, no windows, no mouse support. What did I get into?
You are not the first one to get confused about the intended use case of openHABian or most other solutions based on a Raspberry Pi. Maybe it helps to not think of the RPi as a PC as we know it. It is not (necessarily) build to be used with a keyboard and display. You already own a powerful PC or Mac which you should benefit from. It would be a shame to have a powerful computer at your fingertips and then have to restrict yourself to a very limited graphical frontend on another device, wouldn't you agree?
The intended use case of a lot of these small SBCs is to sit in a corner and provide a service reliably 24/7. You'll find that most solutions for the RPi are characterized by this.
Moving on. What we actually want and what openHABian is aimed for is a dedicated headless system to reliably execute openHAB and to expose all interfaces needed to interact and configure it (PaperUI, BasicUI, HABPanel, openHAB LogViewer, Samba Network Shares, openHABian Configuration Tool, SSH). If you know how to work with these interfaces, you are set for a way better experience than the alternatives. The main challenge is to get used to the Linux command line, not even a GUI (like Pixel, see below) will relieve you from that in the long run. If you are not willing to teach yourself a few fundamental Linux skills you will not become happy with any Linux system and should resort to a e.g. Windows machine. However as you are willing to tinker with smart home technology, I'm sure you are ready to teach yourself new stuff and expand your experience.
If the above didn't convince you, execute the following commands to get the graphical user interface Pixel installed. You have been warned, if there came any warranty with openHABian to begin with, it would end here.
sudo apt install raspberrypi-ui-mods
sudo reboot
After the reboot, connect via SSH and type the following command to start a VNC server to connect to:
vncserver -randr 1280x800
Can I use openHABian on ...?
openHABian is restricted to Debian/Ubuntu based systems. If your operating system is based on these or if your Hardware supports one, your chances are high openHABian can be used. Check out the Manual Setup instructions for guidance.
Differences between systems can still be a problem, so please check the openHABian community forum thread or the Issue Tracker for more information. Do not hesitate to ask!
